Air Filters
LEVER 16062
Air Filters
#1 PostAuthor: LEVER 16062 » Mon May 19, 2008 4:38 pm
Does any one know where I can purchase a set of Air filter pods, K&N or similar ?
#2 PostAuthor: chrisNI » Mon May 19, 2008 5:06 pm
I'd be fairly sure Debbens have K&Ns.
#3 PostAuthor: Pigford » Mon May 19, 2008 6:48 pm
M&P do cheap ones, you just order by carb inlet stub size :!:
About a tenner each... K&N's are twice that :shock:
02GF74
#4 PostAuthor: 02GF74 » Fri May 23, 2008 10:31 am
Pigford wrote:M&P do cheap ones, you just order by carb inlet stub size :!:
so what size whold fit an Z1000 A2? (added to say on standard carbs)
inlet diameter, length?
... and will the carbs need rejetting? (heard they will run too lean on the freer flowing filters or is that a myth?)
what about these for £ 3 !!?
02GF74
#5 PostAuthor: 02GF74 » Fri May 23, 2008 10:44 am
.... can you get a K&N box type filter that sits in the the original air box?
where from? how much?
(mice had eaten my paper elelment one).
#6 PostAuthor: Pigford » Fri May 23, 2008 12:17 pm
I think K&N do a std replacement filter :?:
Just measure the intake diameter of the carbs & have a hunt around - M&P or Demontweaks, etc.
Any freer flowing filter means a re-jet or WILL run lean & cause overheating & even a holed piston :cry:
SP10mk11
K&N Box Type Filter
#7 PostAuthor: SP10mk11 » Fri May 23, 2008 12:28 pm
Hello I have a K&N standard airbox filter in mine (its washable) no difference in performance.
Got it off You know who_Bay
Gary
debben1
#8 PostAuthor: debben1 » Fri May 23, 2008 12:30 pm
K@N airfilter element to fit in the airbox KA8077, in stock £33.90 +
