Calling Z1000 Boffins
CJE
#1 PostAuthor: CJE » Tue Apr 08, 2008 3:14 pm
Can anyone tell me the type of cushdrive and carrier needed for this wheel, Steve Debben has a selection but not sure which one to buy?
Also I am missing a spacer between the calliper bracket and wheel, is this a standard item or something I need to get made? Thanks
RALPHARAMA
#2 PostAuthor: RALPHARAMA » Tue Apr 08, 2008 3:37 pm
I would imagine that with the non standard swinging arm and the brake calliper mounting plate you will end up having to make one. I had to make two up for my bike, which would have been easy, except that I got it into my head that they should be 316 stainless steel and the only lump I could blag was 50mm; hard graft on a little lathe!
By the way CJ, did you used to live in Bristol many moons ago?
Ralph Ferrand
FER
Auld Heedyun
#3 PostAuthor: FER » Tue Apr 08, 2008 7:29 pm
Z1000 A1/2 should fit that wheel , I think!!!!!!!
fer
debben1
#4 PostAuthor: debben1 » Wed Apr 16, 2008 3:43 pm
CJE you have a PM
