Hi everybody,
Was hoping that one of you guys could help me out with some info. I just bought my Z1000-A1 a few weeks ago and have been having some carb problems.
I bought a Haynes manual which was a complete waste of money, It doesn't seem to cover the Z1000-A1 carbs !!!
I'm trying to get a hold of a proper factory manual but I'm
not having much joy at the moment. I'm a bit weary about buying a Clymer manual in case thats as bad as the Haynes.
If someone has a manual could you please let me know what it says about adjusting the idle mixture (screws located
under float bowls), do they state a base setting from
which to start etc, is it then just a case of adjusting the screws until smoothest tickover is obtained.
With the carbs off is the correct float height 24mm ?
If anyone could advise me on the above or even better if you could email me the whole procedure.
Thanks in advance,
Robert....
1977 Z1000 A1 Carbs - Carb info
Just done one of these, screws should be 1 1/4 turns out, I think, I'll check in the morning, from being lightly seated I think the float heights are 27mm although that could be wrong as your supposed to measure the fuel height not the float height. Float heights are made with the bowls off and upside down.
As Mark says 1 1/4 out to start - you're supposed to balance the carbs on the guages to be equal vacuum, adjust your tickover with the big screw, then turn the screws on each carb 'til you get the highest possible tickover that way, amd adjust it to be at the right level with the big central one again. You may need to do this a few times and if the carbs are clogged up much you may see very little difference between right out and right in on some of them but if you end up with it purring nicely you know it'll do.
Thanks for the input guys, it's appreciated.
When I got the bike it hadn't been used for a couple of years. So it had all the usual issues with a bike thats been laid up.
Initially it was a struggle to get it started, once started
it wouldn't idle properly, apart from that it ran Ok.
By Ok I mean no serious engine issues.
The bike has a Harris 4 into 1 and K&N pods.
The carbs are the 26mm with the fuel mixture screw on the
underside (Standard for a 77 A1 I think) The main jet is 124 and the pilot is the standard 17.5
I drained and flushed the tank and cleaned the petcock.
Stripped and cleaned the carbs, they weren't that bad.
The big problem turned out to be the inlet rubbers, they
were perished. They didn't look that bad but when I give
then a squirt with brake cleaner the idle picked up and
smoothed out.
I replaced the rubbers during the week and the bike now
idles pretty good, someone somewhere along the line has
been playing around with the mixture settings. Have given
them some initial adjustment to get the bike running.
I will go back and do a little fine tuning !!!
The points gap and timing was all over the place, the static timing appeared to be on TDC !!!
Have managed to get hold of a Carbtune, the sync is a little out so I will take care of that this weekend.
Robert....
smoothed out.
Robert....
