Great to see some progress.
You won't be disappointed with anything that Nick at Griffs does for you.
My Ultimate Zed
- Zomerset Zed
More.....
I wanted to continue the in-fill work i had done on the rear frame areas to under the seat to give the tail end a nice uncluttered look:
I used 2mm ABS carbon-look
sheets to make the panels from. I have reinforced the top side of the flat panel in front of the number plate with aly angle VHB-taped on. Masking tape is just to mark out and protect the plastic from scratches. I recessed the panels into the duck tail as that is easier than flush to get looking good.
I have made up an aly bracket to hold the number plate which i will cut down once i have a number plate.
I found a suitable LED rear light on Ebay and made up a bracket to fit in the tail piece. I then spent considerable time re-learning the art of forming plastic around a curved object which you don't have. Then trimming it all carefully to fit the light through the hole and get a near fit:
I think i will be re-doing this panel as there are some heat marks on it, the curve isn't quite right and there are a few gaps around the rear edges.
Also got few shiny bits back from Mikey:
