Z1100r my tale of woe
FOZ1A
1100
#91 PostAuthor: FOZ1A » Wed Jan 25, 2017 3:08 pm
Can i ask how much did they charge to do the crank, as i have one that needs doing.
foz
drink feck arse girls
swampy
#92 PostAuthor: swampy » Wed Jan 25, 2017 3:16 pm
You sure can Robin Applebe engineering did the job.
Strip,clean,inspect,balance and weld with new big ends and mains came to £580.
FOZ1A
1100
#93 PostAuthor: FOZ1A » Wed Jan 25, 2017 3:18 pm
Foz
Julian_Boolean
#94 PostAuthor: Julian_Boolean » Wed Jan 25, 2017 4:13 pm
swampy wrote:You sure can Robin Applebe engineering did the job.
Was it a Z1100R crank or one from something else?
(I thought the 1100R had the Unitrak engine and the crank came from the factory with the centre pin welded)
swampy
#95 PostAuthor: swampy » Wed Jan 25, 2017 7:20 pm
original z1100r crank
Julian_Boolean
#96 PostAuthor: Julian_Boolean » Wed Jan 25, 2017 7:49 pm
Was the centre pin welded before it went for refurb - just wondering as I have a Unitrak crank and hope that it's welded.
swampy
#97 PostAuthor: swampy » Wed Jan 25, 2017 7:57 pm
No the pin was not welded as i recall but i could be having a senior moment there.
Basically my intructions where do the bussiness to it.
