Can i ask how much did they charge to do the crank, as i have one that needs doing.
foz
Z1100r my tale of woe
				Julian_Boolean
swampy wrote:You sure can Robin Applebe engineering did the job.
Strip,clean,inspect,balance and weld with new big ends and mains came to £580.
Was it a Z1100R crank or one from something else?
(I thought the 1100R had the Unitrak engine and the crank came from the factory with the centre pin welded)
				Julian_Boolean
