Z1100r my tale of woe
well I'm at new cozzie 1170 pistons 10.5 cr. New A.P.E valves. springs, , guides, seals, cam journals, adjustable cam sprockets and a new cam chain. ( getting) seats re-cut and ports flowed. So a set of Web 110' cams  that are readily available seem like the in for a penny in for a pound solution to me.
And that's just the top end!
Anyone with better tuning, engine building knowledge than I have (not a lot) feel free to jump in!
				neilbarrett
Not posted for a while. So heres an update.
Cleaned and cleaned the cases but could not shift old paint and over spray. So took em down too I Cleenz Machines as the owner is a classic bike nut.
Got em back and spent 5 hours masking them for paint today.
[img][img]http://i1244.photobucket.com/albums/gg574/paulkemp2/Mobile%20Uploads/20161014_133255_zpstqy9bdpc.jpg[/img][/img]
And here is the top case ready for paint.
The head is back with the ports matched, new guides fitted and seats cut for the APE valves. Along with the barrels bored to match the 1170 Cosworth pistons. All work being done by Roger Upperton.
Photos to follow.
Crank is also back from Chris Applebe after being stripped cleaned rebuilt with new mains and big ends then welded and balanced.
So its all systems go now on getting it all rebuilt.
Photos to follow.
						Ok project had wait for a while but new progress has been made.
Cases painted
[img][img]http://i1244.photobucket.com/albums/gg574/paulkemp2/Mobile%20Uploads/20161104_131001_zpsaxyvm4gy.jpg[/img][/img]
Rebuilt crank with new big ends and mains ready to go in
[img][img]http://i1244.photobucket.com/albums/gg574/paulkemp2/Mobile%20Uploads/20160708_113015_zpso5wnuvcx.jpg[/img]
Rebuilt gear box with new 2nd gear on 1st and 2nd shaft and new bearings all round.
[/img]
[[/img]
									Cases painted
[/img]
[[/img]Motor biking, motor biking, going down the queens highway like a rasher streaky bacon!
						Some but not all of the parts that are going in.
[img][img]http://i1244.photobucket.com/albums/gg574/paulkemp2/Mobile%20Uploads/20160727_121603_zpsgfi49dfj.jpg[/img]
Cossie pistons.
[/img]
Crank,gearbox and pistons in.
[img][img]http://i1244.photobucket.com/albums/gg574/paulkemp2/Mobile%20Uploads/20161220_120316_zpswvupreog.jpg[/img][/URL
][/img][URL=http://s1244.photobucket.com/user/paulkemp2/media/Mobile%20Uploads/20170106_111734_zpspkgdyvwv.jpg.html]
Head getting built after Roger Upperton worked his magic.
[img][img]http://i1244.photobucket.com/albums/gg574/paulkemp2/Mobile%20Uploads/20170106_153412_zps0miowtzd.jpg[/img][/img]
Cossie pistons.
[/img]
