Z900 / Z1 Barrels or liners.
cottastaff46
#1 PostAuthor: cottastaff46 » Thu Dec 22, 2016 11:53 am
Hi.
Anyone out there got a set of Z900 / Z1 barrels on standard bores. Not overly concerned about the condition of the fins etc as at a push I can use the liners in my existing barrels. That being the case, a set of liners would also do the job. Mine are already 1mm over and scored which I'm led to believe is the biggest you can go without going up to Z1000 pistons.
Chris.
A1John
#2 PostAuthor: A1John » Thu Dec 22, 2016 11:58 am
cottastaff46
#3 PostAuthor: cottastaff46 » Thu Dec 22, 2016 1:47 pm
Cheers John.
I've contacted Z1 enterprises but that liner is 70mm. They told me that Wiseco do a standard 66 mm liner but they've also replied saying theirs are 70 mm as well. Both the descriptions on the websites are a little misleading.
#4 PostAuthor: z1bman » Thu Dec 22, 2016 2:20 pm
SEP in kegworth / derby will make liners
#5 PostAuthor: ZedHead » Fri Dec 23, 2016 1:17 pm
z1bman wrote:SEP in kegworth / derby will make liners
+1
cottastaff46
#6 PostAuthor: cottastaff46 » Fri Dec 23, 2016 1:17 pm
will give them a try. Ta
