Armature screw
Cajones13
Armature screw
#1 PostAuthor: Cajones13 » Tue Dec 06, 2016 5:11 am
HELP! As is always the case with screws when you have a number doing the same job. Broke the seal on two of the three, then number three chewed out the head. Now instead of an Allen head it has a nice round hole in the top. Any ideas on how to sort it? Was thinking I could Dremel a slot for a stanley tip, but don't want half the screw head fracturing and causing me more grief. Tks
12/78 Z1000 A3A frame running 1980 C3 Police
Julian_Boolean
#2 PostAuthor: Julian_Boolean » Tue Dec 06, 2016 5:33 am
You could try hammering in a torx bit that is a little lager than what's left of the allen hole, but think about where the force that you're applying to that screw head is going - in other words don't hammer the crap out of something not strong enough to take it.
needaz1100r
#3 PostAuthor: needaz1100r » Tue Dec 06, 2016 5:13 pm
That's good advice, the hammering action will help matters too.
Mark.
#4 PostAuthor: PAULJAC47 » Tue Dec 06, 2016 5:58 pm
Yep agree torx,even used one to get out a crappy spark plug!
Cajones13
Thanks!
#5 PostAuthor: Cajones13 » Wed Dec 07, 2016 9:57 pm
Thanks all. I'll give the torx head a try....carefully.
KeithZ1R
#6 PostAuthor: KeithZ1R » Wed Dec 07, 2016 11:34 pm
and if the torx bit fails try a torx socket if there is room, just a backup plan
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
Cajones13
Torx worked!
#7 PostAuthor: Cajones13 » Mon Dec 12, 2016 11:51 am
Thanks guys, t27 Torx bit did the job.
needaz1100r
#8 PostAuthor: needaz1100r » Mon Dec 12, 2016 12:20 pm
Back when I was re-building forks, including changing upside down legs, which meant unscrewing the casing from the leg I used a torx hammered into the allen head grub screw without ever trying the allen key, a bit of heat until the threadlock went soft and it worked every time.
Mark.
