ZRX Engine cover bolts - what tool fits ???
pertonpc
#1 PostAuthor: pertonpc » Fri Nov 25, 2016 4:23 pm
Anyone care to share what they use to get the transmission cover, clutch cover, pulsing cover of a ZRX engine please ?
Looks to be 8mm headed bolts but the recess is too tight and deep for standard socket.
Have tried an 8mm tube spanner but it feels too loose and I am gonna start rounding them off.
Is there a special deep reach socket or what ?
Cheers from Mark
Charlie
#2 PostAuthor: Charlie » Fri Nov 25, 2016 4:52 pm
They are 8mm.
I can get in fine to mine using a deep socket on a 1/4" drive. They should not have much torque on them, so a 1/4" drive set is OK
floydsz1
#3 PostAuthor: floydsz1 » Fri Nov 25, 2016 5:17 pm
8mm deep socket. Make sure you put the same bolts back Into the same holes and if I remember correctly, some allow oil up the side of them. Think there's 2 on the ign advancer cover.
Z1b, z900 A4, zxr750 m2, zrx1200
Z1000 (2003) lawson thingy,
Z1000 (2004) z1b lookalike ,
Z1000j lawson race bike,
Gsxr750H.
pertonpc
#4 PostAuthor: pertonpc » Fri Nov 25, 2016 5:39 pm
Thanks guys
I am in now :D :D
Don't have many 1/4 inch drive sockets but suddenly remembered my trusty Powerfix 26 piece mini tool box.
Had 7,8,9 and 10 sockets - thanks ALDI :oops: :oops:
Just got 16 years worth of crud and chain lube to contend with now.
1/4 inch socket set in better quality needed on my Santa list - don't think these will last too long.
jphaynes669
#5 PostAuthor: jphaynes669 » Fri Nov 25, 2016 7:27 pm
Mark, 1/4 drive set and t bar set are a must on a rex, especialy if your doing stuff with the tank off, it fits between stuff wires etc giving good access to fixings. 6 point sockets are best I find. Long reach magnetic plug sockets are handy too. :wink:
Jeff.H
pertonpc
#6 PostAuthor: pertonpc » Fri Nov 25, 2016 8:17 pm
Cheers Jeff
Good pointer.
Very different fittings to the 70's ones.
Tokico calipers remind me of my GSX 14.
Takes 14 pistons and three discs to stop these vs. one disc and one piston for the original. :wink:
floydsz1
#7 PostAuthor: floydsz1 » Fri Nov 25, 2016 8:21 pm
Front Calipers take a lot off looking after, 6 pistons etc, if any problems with them a lot of people fit mk1 1200 bandit ones. (4 pistons). They work just as good,if not better.
Gsxr750H.
pertonpc
#8 PostAuthor: pertonpc » Fri Nov 25, 2016 8:45 pm
Yes
I have the 6 pot ones on my GSX - one of the first jobs was to free them all off.
Need to investigate the ZRX ones cos it feels like they are binding when you push it - and the back wheel was spinning freely, so it must be a front issue.
PO has fiddled with gold spray so they need cleaning up on outside as well.
How I miss having a main stand :roll:
Charlie
#9 PostAuthor: Charlie » Sat Nov 26, 2016 12:30 pm
I changed my ZRX calipers out for a set of Brembo 4 pots. I was never a fan of those 6 potters. They don't give a lot of feel and are very prone to one or more pistons seizing up.
Nissin (not Tokico) 4 pot calipers are also very, very good too. They will go on as a direct swap. They were fitted to lots of Japanese motorcycles plus some Triumphs.
jphaynes669
#10 PostAuthor: jphaynes669 » Sat Nov 26, 2016 6:32 pm
Agree with charlie, the nissin 4 pots are a brilliant calliper, give good feel and easy to lookafter. I found the standard callipers ok if looked after with regular cleaning and maintenance. But top quality pads and braided lines are an absolute must if you want to get the most out of them.
Jeff.H
floydsz1
#11 PostAuthor: floydsz1 » Sat Nov 26, 2016 7:35 pm
After I'd tried the 4 pots, which worked great I had some radials from a zx6 that I got to fit on my z1000 but never got round to fitting. Had some mounting plates made up for them and they worked great. I then went the full hog and changed the front end. Trouble is with the Rex there's so much you can do to them.
Gsxr750H.
Charlie
#12 PostAuthor: Charlie » Sun Nov 27, 2016 11:41 am
floydsz1 wrote:Trouble is with the Rex there's so much you can do to them.
Isn't that the truth :lol: I ought to be leaving my Rex alone cos I am in the middle of another project on my Zed....but I just can't.
I keep jumping between bikes and doing a bit on each, when I really should be focussing on one or the other ... :roll:
All great fun mind :twisted:
What front end is that with the black stanchions mate ?
