Laser 4 into 1 downpipes
#1 PostAuthor: Al » Fri Nov 04, 2016 3:27 pm
Wanted; laser down pipes to replace mine. (whats the chances???) Just discovered mine have a crack in one pipe (half way round) where it meets the collector and probably too frilly to weld even if i did cut it open. Its down between the pipes as well!
The end of the link pipe is 68-69mm for a 70mm laser silencer which i am doing all that i can to keep for several reasons inc. noise test, baffle changes and physical size. That and the fact that i have two identical silencers.
Photos' to follow when photobucket sorts itself out.
Coose
#2 PostAuthor: Coose » Fri Nov 04, 2016 4:38 pm
Julian_Boolean
#3 PostAuthor: Julian_Boolean » Fri Nov 04, 2016 4:49 pm
I've got a Motad Neta on my Z, if you want any measurements let me know.
#4 PostAuthor: Al » Sat Nov 05, 2016 10:41 am
Thanks all there are some possibilities there but really would like to explore the Laser route first.
Looks ok cos i just painted it, but its not!! :??
