Z650 Kickstart gear mechanism/pawl.
#1 PostAuthor: zed1015 » Fri Oct 21, 2016 12:06 pm
Z650 kickstart mechanism needed for a cunning plan.
Should be 20 tooth i believe.
Any condition just so I can see if it's gonna work or not.
#2 PostAuthor: warren3200gt » Fri Oct 21, 2016 3:45 pm
650 is 20T. Got a parts diagram and part no's list if it helps. Got 2 shafts but both in running engines so not a lot of use to you.
or alternatively
http://www.ebay.co.uk/itm/Kawasaki-Z650 ... Sw-kdX1-ed
PUM 488 June 17
76 Z900A4
77 Z650B1
77 KZ650B1
82 Z1000J2
89 ZXR750H1
92 Blade RRN
#3 PostAuthor: zed1015 » Fri Oct 21, 2016 5:00 pm
Thanks for confirming it is 20t.
I counted them on a pic on an ebay listing.
Just need one to try now.
Not paying DK's fantasy prices though.
Probably only need the actual gear when all said and done.
#4 PostAuthor: warren3200gt » Fri Oct 21, 2016 5:21 pm
13068-035 part no for the 20t cog. Looks like the same part no for all 650's according to partzilla. But no longer available.
PUM 488 June 17
76 Z900A4
77 Z650B1
77 KZ650B1
82 Z1000J2
89 ZXR750H1
92 Blade RRN
GPRD
#5 PostAuthor: GPRD » Fri Oct 21, 2016 7:11 pm
I should have one for an engine I'm rebuilding, what do you need?
What we got here, is failure to comunicate.
#6 PostAuthor: Ginger Bear » Fri Oct 21, 2016 7:53 pm
I can't wait to see what the 'cunning plan' is. :sou
# 104
#7 PostAuthor: zed1015 » Fri Oct 21, 2016 8:19 pm
GPRD wrote:I should have one for an engine I'm rebuilding, what do you need?
Hopefully just the gear to see if it's close.
Don't think I need the ratchet pawl half as that looks to have the same 12 teeth as the z9/1000 and should match.
#8 PostAuthor: zed1015 » Wed Oct 26, 2016 11:14 am
BUMP.
Crofty
#9 PostAuthor: Crofty » Tue Nov 01, 2016 11:55 pm
PM sent
