No.
Does Z1r tank fit J frame
Was looking for something narrower at the back and a bit smaller in physical size. Failed in both departments as the 1R tank is actually not that much smaller when held side by side and only fractionally narrower across the back! It could be made to fit but there are other issues with it too that; the fabrication involved would not be worth the tiny advantage it would give. Combined with the fact that Shed tanks go for upwards of £300 i'll look elsewhere!
						Hobbo wrote:steve.w wrote:yes it does ask big green bus![]()
yes but that did involve two mallets
And tears from Baz
phil
from what I was told his balls were going between the next two mallets
Keith
mistaken.
Phil Churchett winner 2013
mistaken.
