Steering lock removal
harri183
#1 PostAuthor: harri183 » Wed Oct 05, 2016 1:32 pm
How do you remove a uk z1 steering lock from the yoke? Cheers
DavidZ1R
#2 PostAuthor: DavidZ1R » Wed Oct 05, 2016 2:15 pm
If its the same as the 1000a1, there is a tiny slotted screw holding it in, take it out and pull the cylinder out, might want a bit of easing oil.
#3 PostAuthor: z1bman » Wed Oct 05, 2016 7:15 pm
remove the rivet & metal flap then insert the key & turn it a quarter turn then pull it out
harri183
#4 PostAuthor: harri183 » Wed Oct 05, 2016 7:39 pm
Cheers mate saved me again.
harri183
#5 PostAuthor: harri183 » Wed Oct 05, 2016 7:40 pm
Can you re plate them or will it effect the lock.
#6 PostAuthor: z1bman » Wed Oct 05, 2016 8:56 pm
sorry z1 lock is secured with a small grub screw in the bottom yoke i wouldn't advise getting it re plated
DavidZ1R
#7 PostAuthor: DavidZ1R » Wed Oct 05, 2016 9:29 pm
Not the same as a 1000a1 then :oops:
#8 PostAuthor: z1bman » Wed Oct 05, 2016 9:38 pm
David if its on the side of the head stock follow my instructions in my first reply on this post
ogre
#9 PostAuthor: ogre » Thu Oct 06, 2016 9:06 am
mine has a split type of selok pin in the middle of the lock and 2 slots inside the headstock one for locking and one further down for unlocking so just turn the key quarter of a turn so pin in middle should be able to remove it.this is on my z1a.
harri183
#10 PostAuthor: harri183 » Thu Oct 06, 2016 9:57 am
There is a big difference between uk and US steering locks, is your bike a uk one. Cheers
ogre
#11 PostAuthor: ogre » Thu Oct 06, 2016 12:16 pm
yep small barrel with a square locating spigot running along the barrel.
harri183
#12 PostAuthor: harri183 » Thu Oct 06, 2016 1:29 pm
cheers will have a play at the weekend
A1John
#13 PostAuthor: A1John » Thu Oct 06, 2016 2:03 pm
Users browsing this forum: Bing [Bot] and 24 guests
