Another anal type question
can any of you lot remember?
Early pressed alloy rear black/yellow plates
The fittings - were they 2 zinc type nuts & bolts or were the current plastic bolt types used?
I assume they were zinc option as I guess the plastic type would have only come out when when the perspex plates became available around the later part of 1975.
can you enlight?
Alloy pressed number plate fittings
