Well - I had
sold this bike, but the new owner didn't really know much about proper "old skool" machines and kicked up a fuss as the clutch was a bit stiff and said it was unridable
So after a bit of
discussion I took it back - I'm good like that
 The bike has done hardly any miles in the last few years so probably needs a few bits sorting.
Today I wheeled it out of the back of the garage and took a look at it. The left fork seal must be shot as there is a leak from that side so I've removed both forks and will replace the seals - the stanchions are good.
I removed the clutch casing and there is a bit of play in the clutch basket - luckily I have a spare clucth unit with is good - so need to replace it... this may be why the clutch action was a bit stiff.
The bike is also smoking on start-up, but clears after a bit - it didn't do this before I sold it
  So I may have to take the head off and replace the guide seals..... ho-hum
I did a few miles before I put it up for sale and it went well.... so once I've sorted out these glitches it'll be up for sale again.
