Hot starting - Its a H****a but
The problem is with a VF1000F11 that i sold to a mate of mine a couple of years ago. It sometimes don't start when it has done a few miles. its fine from cold even after a few weeks but sometimes won't go after maybee five or ten miles. If its left for a while its then ok. it seems like the battery has gone flat but then without a recharge it is ok.
The problem happened to me a few times and I couldnt work it out I checked earths etc but it sounds like it has got worse for him.
Any ideas.
Baza
(Edited by BShaw at 12:34 pm on Sep. 28, 2006)
Any ideas.
Baza
- rickman CRR
Hi Baz. I'm not an expert but this suggests there might be a problem with the choke system and its still drawing too much fuel when warm. Maybe the choke is permanently closed, (broken cable?) or shut off seals missing or disintegrated when open. Looks like a bag of worms to work on after those panels and tank are removed.
I had not even given that a thought it is cable choke that seems to work ok it don't run rich and only happens when the bike has been turned off for a short while and then only about every 10th time. its weird. and as you say,It is a right pig to work on as well it took me about an hour to get the front two plugs out when i had it!!
Regards
Baza
Regards
Baza
- Davy Doherty
If it starts easy from cold and yet when it's hot doesn't like to turn over as if the battery is flat - I'll put money on the starter motor insulation being knackered. Warm it up so it won't start and check the resistances through the starter to ground, also check the voltage drop when pressing the starter button. V maxes do the same, of course as it's a H****a it isn't user servicable and you'll have to chuck it in the bin and buy another!
Iain marshall
Iain marshall
[img]https://www.ecom.H****a
-eu.com/gma10/EMM/rel/sm/UL004481/html/S2MCW000A0000NFS2MCW000B0000L5[/img]
tried to cut and paste from H****a
site but it wont cause this site does this to H****a
even on the bloody URL
I would check battery voltage 12.5v+ with nothing on,then check it again while turning engine over on the starter, will drop down poss just below 10v with starter turning,then should recover to near battery voltage reading you took if not its past its best,thats just a quick test on condition of battery.To test starter i usualy take it off engine,strip it check brushes,the end bush and front bearing if there worn the armature can short on to outer casing,then i check armature as follows
above pic,check for continuity,with mulitmeter on ohms setting, between pairs of commutator bars,there should be no continuity
then check for continuity between each commutator bar and the armature shaft,there should be no continuity,hope its of some help
(Edited by Iain marshall at 11:38 pm on Sep. 29, 2006)
(Edited by Iain marshall at 12:24 am on Sep. 30, 2006)
cheers Iain can't see your pictures on works pc and still dont have my own but will try tomorrow to have a look on another one. I am at work sat night so can have a better look then. have you an ad for the H****a site and what section its in. saying that I have a H****a common service manual I suppose it should be in that.
Cheers again mate I have bike parts and tools spread all over the SE and no proper access to any of it. I dont even know where my ws manuals are.
Baza
Baza
Iain marshall
Iain marshall
Battery +ve to earth, soleniod output to earth, starter motor input to earth. You will probably find the volts goes down to 6 to 8V when you press the starter button when it's hot. As it happens when it's hot you need to test it then. You will also need to check the case windings as well as the commutator windings. Note that if the insulation is breaking down it may still give the correct continuity reading as what happens is the wires short together passing current but not creating the magnetic field, which means that when you press the starter botton you are just earthing the battery. Also check the resistance between the starter cable back to battery earth and the earth route between the brush plate and starter casing.
Iain marshall
