Battery drain
Battery drain
When I leave the ltd for a couple of weeks the battery is down enough to stop me starting it, before I start poking about with a multi meter I thought I'd ask here first,  is the fuel gauge live all the time as it doesn't move when you switch off.
									1981 KZ1000 K1 LTD
I know nothing about Z1000 Ltds, but could be -
Dodgy battery ?
Could be a faulty Regulator / Rectifier ? vFaulty earth on the Ignition circuit?
Check Earth handle bar / switch gear, Kill switch and Earth wires within Headlamp, and under seat.
Hope you get it sorted. I hate electrics.
									Dodgy battery ?
Everything works as it should including fuel gauge,  charging is spot on,  battery is 1yr old yuasa AGM and keeps charge if disconnected,  I'll have a poke about with the multi meter.
Thanks.
									Thanks.
1981 KZ1000 K1 LTD
