(non American) Wiring diagram needed
davido
#1 PostAuthor: davido » Sun May 08, 2016 3:07 pm
I want to fit European switchgear (on/off light switch) to my American import KZ1000CSR. I have the schematic for the original American(KZ) bike and Im looking for a European (Z)version.I reckon an LTD would be the closest but any Z model from around 80/81 should do.
Can somebody post something please or point me in the right direction.
http://www.kzrider.com/forum/11-project ... ject-build
KZ1000CSR
GSF600Bandit
CBX750F
CB550F
tlc
International Rep
#2 PostAuthor: tlc » Sun May 08, 2016 6:26 pm
Hope this helps.
Actually I'm throwing out an old loom. I'll have a look to see if I have the 8 pin connector.
Asphalt Cowboy
tlc
International Rep
#3 PostAuthor: tlc » Sun May 08, 2016 6:42 pm
I have saved the switch and connectors, male and female (9&4 pin) if you need them.
Asphalt Cowboy
davido
#4 PostAuthor: davido » Tue May 10, 2016 5:09 am
Wow.Fantastic!. What bike is this from? Can you hold off on throwing out the loom.I might need some other stuff as well. Ill look over the diagram tonight and P.M. you later.
Thanks.
tlc
International Rep
#5 PostAuthor: tlc » Tue May 10, 2016 7:46 pm
The diagram is from a non US KZ1000K model. The only non J in the book.
I have now thrown the loom which really was unusable. I did nick a few bits off it to finish mine but you would need to see the bike to believe just what a hatfull of ham fisted owners can do.
The switch and connectors (male and female) I have saved if you want them.
Asphalt Cowboy
davido
#6 PostAuthor: davido » Wed May 11, 2016 5:24 pm
Ok. Thanks Tlc. The diagrams are going to be a big help. The other stuff,you may keep for a worthier cause. I have switches already (from a ZXR) that I plan to fit and I need a some other stuff ,connector blocks and bullet connectors . So,Im going to order the lot from Vehicle Wiring Products or some such place.
Thanks again for the help (and the offer).
