hi all lookin at buyin bt45's for my z1a do i go for 100/90-19 and 120/90-18 v rated tubeless if so can you still fit a tube in on a standard steel rim cos i dont think they do a tube type.
thanks
tyres
If you want an innertube there's one here.
http://www.ebay.co.uk/itm/131323564767? ... EBIDX%3AIT
So this is probably a stupid question but here goes anyway, if you don't put an innertube on a spoke wheel, wont the air escape out through the spokes?
Of all the things I've lost I miss my mind the most
[/quote]
Not if its a bmw. Think guzzi are the same. The spokes are fitted in the side rather than the middle in a seperate bit on the rim etc so not actually inside the tyre.
				johny brando
BT -45's Tires
ogre wrote:cheers thats what i will do then
Thats a very good choice of Tire. I run BT 45's on mine and there brilliant ,very planted ! & definitely stick to STD sizes Tires on Std rims or you will regret it ...handling will be lesser ! Try not to get caught up in this whole big tire thing , as there's a lot more to it than meets the eye . It will rob your H.P. if you have 125 hp plus, well yes .....you need a bigger footprint on the tarmac then & you can afford to sacrifice some Ponies for the privilege. This is why you won't see 120 front & 200 section rear tire's on a Manx Norton or G-50.
- Bill Newman
