Whirring starter motor
Robw
#1 PostAuthor: Robw » Sun Mar 20, 2016 9:15 am
Hi all, I have got issues with the starter on my Lawson. It occasionally whirs when you start it up. I know it's the starter not engaging and i have had the starter out and also checked the rotor which had become loose. The starter seemed fine, when rotated, so I am at a loss now. The battery is fully charged according to the battery charger.
Cheers Rob
#2 PostAuthor: Pigford » Sun Mar 20, 2016 9:50 am
Most likely the 3 x springs & rollers in the starter clutch unit :!: Kits are readily available.
Robw
#3 PostAuthor: Robw » Sun Mar 20, 2016 9:59 am
Piggy, I stripped those down and checked them as one of the bolts had come loose. Replaced the bolt and torqued up the rest. I might get a repair kit any way, just to remove the possibility of this being the fault
Rob
#4 PostAuthor: paul doran » Sun Mar 20, 2016 12:50 pm
It could also be the starter clutch housing
I had similar with My 1100R
changed the springs and rollers still whirring over
changed clutch housing problem solved
#5 PostAuthor: Ginger Bear » Sun Mar 20, 2016 1:02 pm
Have a word with TLC. He's currently having a similar issue sorted.
# 104
tlc
International Rep
#6 PostAuthor: tlc » Sun Mar 20, 2016 1:22 pm
Mine was a worn housing also.
Asphalt Cowboy
Robw
#7 PostAuthor: Robw » Sun Mar 20, 2016 1:33 pm
Cheers for the information, is the starter clutch housing the part that the springs and the rollers sit in? I know that zed power sell them, if that is the case.
Cheers Rob
#8 PostAuthor: paul doran » Sun Mar 20, 2016 3:59 pm
Yes that's correct
