Not Really a Project z900A4
#16 PostAuthor: chrisu » Thu Jan 21, 2016 12:34 pm
Taffus wrote:Hi Paul
Yes it's single disk , I guess double disk is the way to go, any pointers?
change the pads ?
or do what I do on my Z1 - plan well ahead !
Taffus
#17 PostAuthor: Taffus » Thu Jan 21, 2016 1:43 pm
ordered some Ferodo pads (they work well on the car)
Changed the fluid as it was dark brown
Pads have some chunks out of them I guess they are on their last legs
had a 20 mile ride this morning and it rides really well. engine is strong and tractable.
Got a black and silver plate (from the Bunnyz school of cool)
Clutch still has a high bite piont but I'm getting used to it
(\__/)
(")_(")Image
#18 PostAuthor: PAULJAC47 » Thu Jan 21, 2016 2:52 pm
Re clutch Markm have you adjusted it via the nut and slotted screw under the eye shaped panel on the casing?
Taffus
#19 PostAuthor: Taffus » Thu Jan 21, 2016 2:53 pm
No, I'll give it a go
(\__/)
(")_(")Image
#20 PostAuthor: Garry.L » Thu Jan 21, 2016 5:06 pm
I'd think Rolling Stoppies are an unlikely event on a single disc A4. Braking needs to be very much a planned event.
I stripped, cleaned and fitted new seals, new fluid and new sintered pads on my A4 and it made little difference. About the best I could say was my bike had genuine ABS.
#21 PostAuthor: chrisu » Thu Jan 21, 2016 5:33 pm
Taffus wrote:ordered some Ferodo pads (they work well on the car)
don't forget to retorque the head
Taffus
#22 PostAuthor: Taffus » Thu Jan 21, 2016 6:15 pm
Next Job after the clutch adjustment Chris!
(\__/)
(")_(")Image
Taffus
#23 PostAuthor: Taffus » Sun Jan 24, 2016 1:16 am
ok, new pads in, I was a bit confused as the pad that fits in the floating bracket was very tight (as was the one I removed) I rang my mate Steve Bowdler and he advised trimming it a bit.
After I did this all felt more smooth, braking performance is not great but the pads need some time to bed in
(\__/)
(")_(")Image
bunnysZ
Granny Magnet
#24 PostAuthor: bunnysZ » Sun Jan 24, 2016 6:51 pm
Taffus
I upgraded to twin discs , didn't make much difference to the braking ,
but looked a lot cooler
