Good afternoon,
any recommendations for frame and various bracket paint on a z1000a1?
I want to replicate the slightly off gloss black (not satin) finish used on these bikes, as full gloss don't look right, which is probably why kawa didn't use it.
I'm a bit sniffy about powder coating because I don't know if the proper off-gloss finish will be available, and I've seen several instances where water has got into a chip in the finish and rust has propagated under the coating in a big patch. That said, it seems to be the solution with the least effort on my part.
I recently saw a Norton frame in a mates bike shop with a finish that was a dead ringer for a factory finish, that was apparently black smoothrite. I expect its a pain to do though.
The same goes for the black brake calipers - what's best? I'll almost certainly paint these at home though.
Thanks,
Olly
frame and caliper paint
- wheelysteve
frost extreme chassic paint for the frame and brackets
http://www.frost.co.uk/search?q=extreme ... is%20black
- Rob McCool
