Fuel hose routing
roosterrs
Fuel hose routing
#1 PostAuthor: roosterrs » Mon Nov 23, 2015 9:57 pm
After 12 months I have got the carbs back on my GPz750A3.
I am in the process of connecting the hoses back up, but can't find a routing diagram.
Does anyone have one?
I have the petrol tap connected between carbs 2&3. Petrol tap vacuum to carb 2 vacuum. The tee pieces between carbs 1&2 & 3&4 are overflows. I then have a long hose from the fuel level sensor at the RH front of the tank which I think is another breather, anyone confirm?
Lastly I have a 4.5mm hose which has a small brass restrictor in it which connects to the carbs according to the parts diagram. Anyone know where this goes? Does it go to the top of the airbox?
Thanks in advance for the help.
