oil cooler pick ups
oil cooler pick ups
Wanted oil cooler pick ups, would like the type that take the standard z1 pressure switch but would consider non switch type.
Andy, I have ordered a set from that guy in the states as in the ebay link. When they arrive I could send them up to you for the dimension purpose....or if the guys here in work are feeling particularly helpful they might be prepared to put the dimensions down in an AutoCAD diagram. I could send the AutoCAD diagram to you in a PDF format if you don't have AutoCAD.
Hi Andy.
Debben do some
http://www.debben.co.uk/oilcoolertakeoff.html
or I have 3 different types if you want to BORROW some
Gus
Debben do some
Gus
"Set the GRINDER on it"
