CSR 1000 front disc. any other model fit ?
Hi Guys, I'm not having a lot of luck finding a front disc for my CSR 1000. Every other model seems to be bigger or smaller. Does anyone know if any other bike shares these discs ? Or do you have one you might want to sell me,  I've asked a couple of engineers up here if they could straighten my old one with no results,  thanks $tevie.
									stephen g mackay
						Sorry cant help -  EDITED .
[b]WRONG WHEELS SHOULD BE SPOKED [/b]
				johny brando
Re: CSR 1000 front disc. any other model fit ?
stevie g wrote:Hi Guys, I'm not having a lot of luck finding a front disc for my CSR 1000. Every other model seems to be bigger or smaller. Does anyone know if any other bike shares these discs ? Or do you have one you might want to sell me, I've asked a couple of engineers up here if they could straighten my old one with no results, thanks $tevie.
I've just looked a set of GPZ 1100 B2 front disc's & they look absolutely exactly the same as yours ! they measure up @ approx 285mm O/D & 130mm I/D , same & 7 bolt fix , same disc drilling pattern, same disc face rebate..........I recon it could well be them !!!
Hope this helps . Johny Brando.
They are 270 OD x 5mm thick x 4 bolt fixing. Mine is the CSR M1 wire wheel. There are lots that look the same but are usually too big a OD
									stephen g mackay
Cannot do that cos the drilled holes will be either too close to the edge or actually on the edge and don't think there's any out there that are not drilled as standard.
									stephen g mackay
				johny brando
johny brando wrote:stevie g wrote:Hi Guys, I'm not having a lot of luck finding a front disc for my CSR 1000. Every other model seems to be bigger or smaller. Does anyone know if any other bike shares these discs ? Or do you have one you might want to sell me, I've asked a couple of engineers up here if they could straighten my old one with no results, thanks $tevie.
I was using the photo that was shown on this thread ( & is now "not displayed any more !!!!" as the reference for my above reply ) why did I bother to measure check & reply !
As Z1bman says,  Alloy centre fixing is 8 rivets, 4 bolt pattern fitting to wheel, 270 mm OD  130 ID  x 5 mm .  Even if I could get one with same OD and ID but with a different Alloy centre maybe I could get it changed, or is that possible ?
									stephen g mackay
						Give these people an email, rear listed but can't see front.
http://www.ebay.com.au/itm/MetalGear-Br ... 2327629406
http://www.ebay.com.au/sch/m.html?_odkw ... c&_sacat=0
