Z1R Silencer / Centre Stand bump stop
Kev1R
#1 PostAuthor: Kev1R » Sat Aug 29, 2015 2:57 pm
Spent some of today putting shiny bits and painted bits back on the Z1R.
I am fitting an aftermarket silencer (though near identical to original).
Problem is the rubber stop to the centre stand needs inserting in the silencer bracket.
The stop - where it goes in the bracket - is conical shaped, but at its narrowest point is about the same diameter as the hole. It is simply too big & wide to go in.
I have tried heating it in boiling water to make it more pliable and also using washing up liquid as a lubricant but to no avail.
I know one or two people have fitted these silencers and wondered if there was an easy way to do this -
(apart from filing the rubber down to make it smaller!.)
Kevin
010
Reecy
#2 PostAuthor: Reecy » Sat Aug 29, 2015 3:18 pm
Kevin,
Try harder :D
I used hot water, washing up liquid and a pointy screw driver pushed through the hole to lever the tip of the cone through the hole- that will do it
Atb
Reecy
Kev1R
#3 PostAuthor: Kev1R » Sat Aug 29, 2015 3:34 pm
That sounds like my school report!
Ok I will try again
010
KeithZ1R
#4 PostAuthor: KeithZ1R » Sat Aug 29, 2015 4:57 pm
dip it in unleaded :lol: it will fall in
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
pertonpc
#5 PostAuthor: pertonpc » Sat Aug 29, 2015 5:29 pm
Agreed
It will fit eventually but it is an absolute pain - worse than Z1 silencer stops and they aren't easy.
It's almost like it has been made slightly oversize.
Persevere and you will get there.
I lubed it with washing up liquid, clamped the bracket in a workmate and then used a flat blade screw diver to ease the rubber into place whilst turning it under pressure to get more to go under.
From Mark
HowieD
#6 PostAuthor: HowieD » Sat Aug 29, 2015 8:52 pm
ha ha
I remember taking mine out to paint the bracket and couldn't get it back in again. I ended up using a door stop rubber from Woolies and bolting it in with a big washer on the bolt.
CD185, Maggot, Z1-R, Horace
Kev1R
#7 PostAuthor: Kev1R » Sun Aug 30, 2015 9:22 am
I can report it that indeed it will fit if forced
I can also report that a small flat blade screwdriver will produce alot of blood if forced into your finger - I do not recommend that method.!
010
#8 PostAuthor: chrisu » Sun Aug 30, 2015 2:27 pm
Not my choice of lubricant
Ouch
Users browsing this forum: Google [Bot] and 12 guests
