Neutral Switch Query
Tonto
#1 PostAuthor: Tonto » Tue Jul 28, 2015 4:09 pm
Chaps - neutral light failed last week, changed bulb and no joy so took a look at the neutral switch and it was dangling in the breeze.
Problem is I cant seem to re-attach it and nothing in my service maual shows any detail of how it fit into the retainer. Have I lost a compnent that it should locate into ??
Any advice appreciated - Cheers Tim
Z900 A4 / KZ1300A1 / H1F 500 Project / CBX Project / RD350 project / GT750A Kettle / BMW R NineT
KeithZ1R
#2 PostAuthor: KeithZ1R » Tue Jul 28, 2015 4:16 pm
its snapped off, you need to remove the broken threaded bit and replace the whole thing
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
Z1parR
#3 PostAuthor: Z1parR » Tue Jul 28, 2015 4:20 pm
It's knackered Tim :wink:
The switch body has cracked through and the guts have fallen out .
A flat bladed screwdriver will undo the threaded portion of the body from the motor .
A new switch then will sort it :(
0172 . Geoff Parr
Z1parR
#4 PostAuthor: Z1parR » Tue Jul 28, 2015 4:21 pm
Wot Keith just said :oops:
0172 . Geoff Parr
Tonto
#5 PostAuthor: Tonto » Tue Jul 28, 2015 6:01 pm
Guys thanks, I hadn't realised it had snapped in two :oops: .
I mistakenly thought the yellow hex top screwed into the main body -- doh !
I'll order a replacement from Z-Power tomorrow
Cheers Tim
wilsonsjw11
#6 PostAuthor: wilsonsjw11 » Wed Jul 29, 2015 6:06 am
Tim,
The plastic item is now NLA.
You will get a steel item as the replacement part that comes with a push on connector rather than the screw terminal.
Regards
Steve
