Cam chain replacement
DavidZ1R
#1 PostAuthor: DavidZ1R » Wed Jul 01, 2015 7:27 pm
it possible to change the cam chain on my 550 in situ without taking the feckin engine to bits? if it is how is it done?
Ta
:shock:
#2 PostAuthor: z1bman » Wed Jul 01, 2015 9:03 pm
not unless you use a soft link cam chain. you can leave the barrel & cylinder head on if your only replacing the chain but it would be false economy not to replace the rear cam chain guide & if you do that its a full engine strip
