new wiring looms
1962royp
new wiring looms
#1 PostAuthor: 1962royp » Fri Apr 10, 2015 12:30 pm
Guys
I have a GPZ1100B2 do we know anybody that could do me a new pattern loom.
I want to keep the injection system for originality.
I have 7 volts at my clocks on mine and this makes my dash display refuse to work.added 12 volts it works.
Im thinking i should just get a new one or a good second hand one to replace it rather than repair it?
Thanks for reading and feedback in advance.
GPZ1100 B2 owner
GPz 305 project
99% Gpz1100 unitrac Nearly there
Garn 1
#2 PostAuthor: Garn 1 » Fri Apr 10, 2015 5:26 pm
1962RoyP, Have a check of your kill switch and ign switch. You may find its just a high resistance contact. You may also want to look at the use of a simple relay to up your voltage. That Wg ign mod definitely can swamp out bad connections.
1962royp
new wiring looms
#3 PostAuthor: 1962royp » Fri Apr 10, 2015 5:32 pm
Will do I have a mate thats a sparks on trucks ill get him on it.
Cheers you must be up early
GPZ1100 B2 owner
GPz 305 project
#4 PostAuthor: chrisu » Fri Apr 10, 2015 11:02 pm
Get yourself a can of contact cleaner as a minimum. disconnect everything, spray and reconnect
As said especially the switches.
