3/8 offset front sprocket for GPZ .
KWACKERZ1
#1 PostAuthor: KWACKERZ1 » Wed Apr 01, 2015 11:34 am
Anybody help with this as debbens only list a 5/8' offset one.
#2 PostAuthor: ADRIAN H » Wed Apr 01, 2015 12:52 pm
Talon in Yeovil, make offset sprockets. Ask Piggy for contact details if you cant find them.
KWACKERZ1
#3 PostAuthor: KWACKERZ1 » Wed Apr 01, 2015 1:52 pm
Adrian, thanks i have had some talon stuff before, just wondered if anyone had one kicking around.
#4 PostAuthor: Al » Wed Apr 01, 2015 5:00 pm
How many teeth?
I have one but will have to go see.
You could ring Ray as he does not always keep his stock list up to the minute!!
Gus
#5 PostAuthor: Gus » Wed Apr 01, 2015 6:15 pm
Talon supply Debben
"Set the GRINDER on it"
tlc
International Rep
#6 PostAuthor: tlc » Thu Apr 02, 2015 6:48 am
I bought a 3/8 530x17 in error and was going to return it.
Would that suit you?
Asphalt Cowboy
KWACKERZ1
#7 PostAuthor: KWACKERZ1 » Thu Apr 02, 2015 8:33 am
Chris,
Yes thats ideal.
Will pm you.
brian 1100
#8 PostAuthor: brian 1100 » Thu Apr 02, 2015 7:32 pm
Just some useful info for anyone else, you can use a 530 pitch ZX10 (1988-90) front sprocket.
This has the same spline to fit the Z1000J/R and 1100/R/GPz.
It will give a 6.3mm offset but you can still put a 3mm washer behind it to give 10mm (3/8 inch) offset.
Sprocket ref is JTF527. Available in 16 and 17T
I've just fitted a 16T one with a washer behind it (ordered from B&C Express for about £15).
And as Zorded and I have discovered over the winter whilst changing wheels, it would appear on a standard Z/J it the front sprocket is 2-3mm offset!?
Probably an early design/tooling mistake that wasn't serious enough to bother correcting.
Brian
