Sidestand for a J
Sidestand for a J
#1 PostAuthor: Al » Sun Mar 29, 2015 12:26 pm
I need a longer sidestand for the J.
Perhaps the Euro J stand is longer (the one with the dog leg in it) or possibly an 1100R one.
What have you got?
Mine is 11 inches bolt centre to toe tip.
tlc
International Rep
#2 PostAuthor: tlc » Sun Mar 29, 2015 1:16 pm
My measurements of Euro J and Unitrak show they are the same at 11"
Asphalt Cowboy
#3 PostAuthor: Al » Sun Mar 29, 2015 1:38 pm
Thanks Chris i remember you looking at this before.
Did you get as far as measuring an 1100R one or are they the same at 11 inch.
jphaynes669
side stand.
#4 PostAuthor: jphaynes669 » Sun Mar 29, 2015 7:02 pm
Hello Al, Had a similar issue after raising the back end of my 1000j by 40mm, soon found out I needed a longer stand. All my research was fruitless...nothing! Worked out that it needed to be 330 long. So I cut it just below the peg for the spring, fabricated a piece of tube ( bottle jack handle I think :lol: ), lined it all up and welded it, little bit of work with a flap disc, couple of coats of grey primer and paint and job done....and you can hardly notice
the joints.. Give it a go! :wink:
Jeff.H
tlc
International Rep
#5 PostAuthor: tlc » Sun Mar 29, 2015 7:36 pm
zorded wrote:Thanks Chris i remember you looking at this before.
Al.
I'm not sure if my 1100R stand is actually the correct item. I had a UK J frame as you know which used the 3 spring version. The 1100R frame is the same as my Euro J but I have fitted a Unitrak stand which whilst it is the same length is cranked in such a way that it fits nicely around my rearsets.
Asphalt Cowboy
#6 PostAuthor: Al » Sun Mar 29, 2015 9:34 pm
Hello Al, Had a similar issue after raising the back end of my 1000j by 40mm, soon found out I needed a longer stand. All my research was fruitless...nothing! Worked out that it needed to be 330 long. So I cut it just below the peg for the spring, fabricated a piece of tube ( bottle jack handle I think Laughing ), lined it all up and welded it, little bit of work with a flap disc, couple of coats of grey primer and paint and job done....and you can hardly notice
the joints.. Give it a go! Wink
Thanks JP i may end up having to do that but its a slippery slope that way and before you know it you're cutting bits from the frame. :D
Chris yours looks like an 1100R one but here is an original as far as i know.
Not a great picture, the bike was doing about 50 and the camera about thirty metres away
#7 PostAuthor: Ginger Bear » Mon Mar 30, 2015 6:47 am
Al,
Have you considered this sort of thing?
http://japan.webike.net/products/1522797.html
http://japan.webike.net/products/20992523.html
Possibly Dave at Saisei could source you one, or you could consider re-engineering yours in a similar fashion. :wink:
# 104
#8 PostAuthor: Al » Mon Mar 30, 2015 9:34 pm
Thanks Steve very neat and tidy that.
Not seen those before but did have something similar on my trials bike.
Taffus
#9 PostAuthor: Taffus » Mon Mar 30, 2015 9:37 pm
I have an R side stand here if you want to try it.....I will need it in the future though :roll:
(\__/)
(")_(")Image
#10 PostAuthor: Al » Mon Mar 30, 2015 9:47 pm
Thanks Mark i only need it for nine days.
1 in April
2 in May
2 in June
4 in July
and 2 in October
You can have it back in between if you want.
P.S. Litre R or 1.1? is it longer than 11 inch??
Taffus
#11 PostAuthor: Taffus » Mon Mar 30, 2015 9:53 pm
came of fthat R frame...you know the one that has become the never ending money pit of ideas! :lol:
(\__/)
(")_(")Image
#12 PostAuthor: Al » Mon Mar 30, 2015 9:59 pm
Oh yes that one!
Hey its only money.
big green bus
#13 PostAuthor: big green bus » Wed Apr 01, 2015 4:17 pm
I will have a look tomorrow Al and see if I have anything
#14 PostAuthor: Al » Wed Apr 01, 2015 4:59 pm
Thanks Steve i look forward to hearing.
Only needs to fit and hold it up, nothing fancy.
#15 PostAuthor: Ginger Bear » Thu Apr 09, 2015 7:08 pm
Al,
I've just been 'rooting about' in the shed & found what I think is a Unitrak stand, which appears to be a good half inch longer than your's. :crnk
If you PM me an address I'll get it off to you asap.
# 104
