Clutch Nut - Shaft Drive Engine
LTD Project
#1 PostAuthor: LTD Project » Sun Mar 29, 2015 4:11 pm
Okay, so the manual says put engine in low gear and stand on the rear brake.
Fine if the engine is in the bike but mine is on the work bench.
Any ideas of getting the clutch off without splitting the cases and putting the whole clutch shaft in a vice?
Anyone been here before?
Image[/img]
KZ1000 B4 on the road, KZ1000 B4 under serious restoration, KZ1000 B3 waiting it's turn.
GB's old snotter in the operating theatre at present!
#2 PostAuthor: z1bman » Sun Mar 29, 2015 4:17 pm
either use one of these or use a air/ windy gun
http://www.ebay.co.uk/itm/Motorcycle-Cl ... 2a4dcb7b5d
Garn 1
#3 PostAuthor: Garn 1 » Sun Mar 29, 2015 4:25 pm
Try a rattle gun, with the appropriate 28-30mm socket. They are usually very tight.
Please note, you may not be able to achieve much as the clutch housing will still not be able to be removed from the engine. Some engines undergo a mod to allow for this removal procedure. It requires extensive milling of both halves of the engine cases. My opinion is, you will have to split the cases.
#4 PostAuthor: z1bman » Sun Mar 29, 2015 4:30 pm
why are you removing the complete clutch? if you are only checking/replacing the plates there is no need to undo the centre nut
LTD Project
#5 PostAuthor: LTD Project » Sun Mar 29, 2015 4:59 pm
Sacrificial engine, want some clutch parts, ST uses same clutch as GPZ....
Any way air hammer ratchet thing did the job. so many times now I have forgotten that that little baby sits in the corner of the garage, care of Aldi.
Usually covered in so much junk: out of sight out of mind.
Its great when I remember it is there! :oops:
Thanks for quick suggestions, onwards to next job.
Vendetta761
#6 PostAuthor: Vendetta761 » Tue Mar 31, 2015 8:33 am
ooooh, does that mean you may have some unwanted ST engine bits ? :oops: :lol:
Z1000 ST x 3 , Moto Guzzi G5 special ,V11 special.
