wont ffin start
keith mayall
Re: wont ffin start
keith mayall wrote:had the carbs cleaned,refurbed.get a spark when contact the points with a driver..seems no fuel as the plugs aint wet...where do I start.getting nothing.
if theres anyone in the north Manchester area willing to check it out would be good.
do you get regular sparks at the plugs when you crank it over on the starter ? if not check you have rubbed off enough of the powder coating to get a good circuiy with the coils, also measure the resistance of the coil through the plug to earth - I think it should be around 5ohm ??, possibly 3 but I stand to be put right as its from memory, check all 12v connections .
keith mayall
