Checking Valve shims
- PETER KZ1A
				LTD Project
Sorry to drag this one out but....
Further to the point that xsfool and Pigford discuss on which way the cam should be pointing to take the correct reading.
In my GPZ1100 (Unitrak) manual supplement it directs you to take the reading with the central line of the cam in line with the mating surface on top of the head.....
Anyway, views on this instruction from Kawasaki as the reading with the cam set like that is definitely smaller than the 180 degrees from the valve as shown by Chrisu
Whadayafink?
Whadayafink?
KZ1000 B4 on the road, KZ1000 B4 under serious restoration, KZ1000 B3 waiting it's turn.
GB's old snotter in the operating theatre at present!
				LTD Project
				nick pearce
Valve guide.
Thanks for putting up the guide Chrissu. Does anyone have the correct tolerances for the GPZ1100 unitrak with road going kent cams in it. Ive lost the bit of paper I had it written on. Cheers Nick.
									N Pearce
						Re: Valve guide.
nick pearce wrote:Thanks for putting up the guide Chrissu. Does anyone have the correct tolerances for the GPZ1100 unitrak with road going kent cams in it. Ive lost the bit of paper I had it written on. Cheers Nick.
You want to be on the wide side.
Anywhere from 0.15 mm up to 0.18 mm.
Yoshi quote 0.20mm for their ST2 and ST3 cams.
				nick pearce
I take it that I have to put the cam chain tensioner back on a J engine to check the valve shims, it does not say anything in the Clymer manual, but it does say to remove it before putting the cam cover on
									1981 KZ1000 K1 LTD
It will help.
If the chain is slack the valve springs will advance / retard the exhaust cam and the chain will jump a tooth or two.
Soon as you can get a look at the cam timing marks when the crank is aligned with the correct timing mark.
'F' mark or 'T' mark?
The inlet cam mark (dash) will likely be out since correct timing of the inlet cam is related to a curved lowereing (shortening) of the top chain run.
The fixed blade inside the cam cover is responsible for this anomaly.
If you want to set the cam timing accurately or want to change the standard cam timing you will need a load of stuff like DTI with extended plunger, magnetic mounting base and bolt down plate, fake cam cover slipper blade, degree disk etc etc.
						Al, I first read your post at 7am and to be honest it was brain overload, I have not ever done this before, I managed to get some time today and the results are number 1, inlet 0 still move shim, exhaust .05
2, inlet 0 still move shim, exhaust .05
3, inlet .05, exhaust, .05
4, inlet 0 still move shim, exhaust 0 still move shim
so am I right in saying that soon I will have to change some shims as the gap gets smaller with more miles on the clock or is it the other way.
Graham
Graham
1981 KZ1000 K1 LTD
