Removing engine from frame
sprint
#1 PostAuthor: sprint » Sat Feb 07, 2015 1:40 pm
Which is the best/safest way to remove the engine from the frame?
I have the head and barrel off but it still seems a very unwieldy lump to lift and clear the frame?
Does it make and difference/help to remove the stator and cover?
martinz1000r
#2 PostAuthor: martinz1000r » Sat Feb 07, 2015 1:56 pm
Easiest way is lie the bike on it's side with engine on an old sofa cushion or similar and lift the frame off. Still recommend 2 people though.
sprint
#3 PostAuthor: sprint » Sat Feb 07, 2015 2:08 pm
With wheels and forks still attached not very practical for me. Is there particular way or routine to follow to remove it out of the frame with it upright?
#4 PostAuthor: z1bman » Sat Feb 07, 2015 2:48 pm
it gives clear instructions in the genuine workshop manual of how to remove the engine
Z1parR
#5 PostAuthor: Z1parR » Sat Feb 07, 2015 2:53 pm
Ideally you'll need two men , and equal amounts of muscle and swearing .
I wrap the frame with insulation tape anywhere that i think it'll get scratched .
0172 . Geoff Parr
weaver
#6 PostAuthor: weaver » Sat Feb 07, 2015 5:10 pm
I used a trolley jack with a piece of mdf bolted to it,get it under the engine to take the weight,remove the bolts and lift out with a mate,easy :) pipe lagging can be used to protect the frame
jimmock
#7 PostAuthor: jimmock » Sat Feb 07, 2015 5:27 pm
I cut off all the offending frame tubes with a grinder.
Jimmock. :wnkr
I hate people I don't like !
neilbarrett
#8 PostAuthor: neilbarrett » Sat Feb 07, 2015 6:29 pm
Helps to remove the exhaust studs if there fitted.you should be able to lift it out fairly easy if theres no top end on
mick znone
#9 PostAuthor: mick znone » Sat Feb 07, 2015 6:44 pm
jimmock wrote:I cut off all the offending frame tubes with a grinder.
wish id thought of that, i used a hacksaw, took me ages, :x
got it out though :wink: :up
mick znone
#10 PostAuthor: mick znone » Sat Feb 07, 2015 6:45 pm
best wishes Sprint, hope it goes well :up
Richard Q
#11 PostAuthor: Richard Q » Sat Feb 07, 2015 6:52 pm
I found it useful to have a platform of the same height as the engine next to the bike. Pallets, stool, pile of bricks with a piece of wood or whatever. Drain the oil and remove the oil filter as this sits low under the engine.
Take the weight with a trolley jack with a short plank of wood under the engine. Undo the engine bolts and remove. Jack it up a little, then you can Manoeuvre/manhandle it onto the platform without having to actually pick it up.
Worked for me :)
1976 KZ900
