GPZ1100B2 rebuild cellar find
1962royp
#1 PostAuthor: 1962royp » Sat Feb 07, 2015 8:43 am
Guys
Electrical help needed.
I have got to rewire stage and im missing a wire to a thick white and pink singlemale from or to the fuse box does this need to go to the battery positive side?
Also i have a male black wire coming from the rear of the loom is this an earth.
Pics would be spot on.
I have the gen manual but its not on the bike is it.
GPZ1100 B2 owner
GPz 305 project
99% Gpz1100 unitrac Nearly there
Richard L
#2 PostAuthor: Richard L » Sat Feb 07, 2015 2:47 pm
Hi
Not easy by email but here goes. Pink red /white cable go into double connector which goes to battery plus terminal
This is the cable
I guess this is the male black bullet at the rear of the loom here on the right of picture.
This fits into the double black connector that comes out of the middle of the loom and joins to the starter solenoid black wire pictured here.
I.E. it fits in this empty double connector pictured here .
Hope this makes sense if not let me know and I will try further explanations
Richard
1962royp
#3 PostAuthor: 1962royp » Sat Feb 07, 2015 2:58 pm
Thats excatly what im looking for is that a pink in with the white and red
Thanks again guys it turns over now and sparks just to clean tank out and put fresh petrol in .
GPZ1100 B2 owner
GPz 305 project
#4 PostAuthor: z1bman » Sat Feb 07, 2015 3:14 pm
the pink wire is for the battery level sensor if the battery doesn't have the sensor it is connected to a permanent live like what has been posted
