Hello There,
Going to tidy up my forks with new dust seals and fresh oil.
Has anyone got the Kawasaki Service Manual for Z1-R D1 1978 handy to say which viscosity of oil and how many cc's it takes please?
Or anything else useful it says about doing it - such as how many mm from top of fork the oil should be when it is right.
Thanks from Mark
Z1-R Fork Oil - Capacity & Grade from FSM needed Please
My manual says the D1 spec is the same as A2 -
works in capacity rather than mm from top - others may be able to advise.
each fork capacity is 180 ~ 188cc
Oil Type: SAE 15W
I would think the volume of oil assumes the fork is completely drained empty.
If I were taking apart completely I might consider a fork spring upgrade.
Oil Type: SAE 15W
010
That's lovely thanks Keith,
I knew you would know !!
Been busy on the motor today - but forks are next
From Mark
From Mark
Cheers Kev,
I want to try and leave the springs and everything else standard.
http://www.zedrider.co.uk/z1-r.html
Plan is to get the forks off, wash out the internals, replenish correct oil and fit new outer seals - they have cracked a bit with age - inner seals still holding ok.
But thanks for the help.
From Mark
From Mark
