Hi All
Further to my various posts about trying to identify the forks on my z1000A1, I am planning to replace the rear wheel with a bandit 600, which I have, as this will fit into the mechamex swinging arm on the bike. With that in mind what would you suggest that I put at the front end that would compliment this and would fit the hand made yolks which take 36mm diam upper tubes ?
Any input much appreciated.
Chris
Which more modern front end for my Z1000A1 ??
If you buy a complete front end, you will be looking at swapping over the steering stem from your existing triple tree setup to the bandit setup, adapting the ignition switch and clocks to fit the new yokes, probably altering the lock stops to stop the new forks hitting the tank on full lock. It'd be wise to drop new steering bearings in while it's all off too.
