Heavy Clutch
Heavy Clutch
Hi Guys,
Riding my Z1 and pulled clutch in and it felt like the cable broke but it had'nt and still had a bite at the end of the the lever.
I tried adjusting the clutch but it was very heavy on the lever, so went through it and found that the friction plates were very difficult to remove, which i felt was odd.
I had replaced the clutch with A.P.E ones and the pusher and release gear when I first got the Z and has never been a problem.
I have even tried putting it back with all the original parts and the clutch is still heavy.
Any Idea's. ???????? Thanks Wil.
1973 Z1 1974 Z1A
wilsonsjw11
Heavy Clutch
Hi Steve,
Yes greased release mechanism, and yes the plates are A.P.E with an extra presssure plate.
1973 Z1 1974 Z1A
wilsonsjw11
Heavy Clutch
Hi Steve,
Yes, the same.
I have lubed the cable, greased the release mechanism, clutch rod, and pusher.
Everything moves fine, but when I put the spring plate back on and tighten up the bolts, it becomes very hard to pull in the clutch.
I have dismantled it down to removing the plates a few times and although the clutch will work, it is not right.
I have a Z1A that I have just restored and even with the standard clutch it is quite easy to use.
Yes, the same.
1973 Z1 1974 Z1A
Heavy Clutch
Hi Z1bman,
When I stripped the clutch I had the A.P.E extra plate installed and found the friction plates were tight on the tangs, so I put the original plates, pusher, springs,clutch rod and release arm back.
The friction plates went back easily compared to the A.P.E ones and I don't think the A.P.E were tight when I first fitted them, ?
I have tried both sets of springs with no difference and are not binding, lever the same pressure bake to the bars.
1973 Z1 1974 Z1A
Heavy Clutch
Hi Crofty,
That sounds like what could be happening, but I can't see where the plates have worn the fingers to cause the clutch be be heavy.
And as I see it the pusher only lifts the spring plate and not the friction/Pressure plates, ?
I do ride the bike quite hard but the A.P.E clutch has been in for years now and never had a problem till now.
1973 Z1 1974 Z1A
Heavy Clutch
Hi Z1bman,
It do'es seem to be something to do with the spring plate as with it off the lever to pusher is fine with a finger over the pusher it moves freely.
Everything lines up on spring plate and tightened down evenly.
1973 Z1 1974 Z1A
Heavy Clutch
The spring plate slides on the inner basket mounting lugs and bolts down, I can't see how you can misalign it, ????
1973 Z1 1974 Z1A
Users browsing this forum: Google [Bot] and 22 guests
