well today I bought a Kawasaki z1 that had been sitting in a barn for 9 years
from what I can tell it has a gsxr usd front end with zzr1100 wheels.a deep braced jmc mono shock arm.
I know the history of this engine as it was blue printed and had work done on the crank and rods and different cams fitted and was used in a side car outfit many a year ago.
as you can see it needs a lot of work and stripped and rebuilt.
thing to change are a set of renthal bars and risers.
change the rasket rear sets to something more adjustable to suit my leg.strip and rebuild the engine ,I also got a bank of rs flatslides with it which will need rebuilt.so I will be starting a rebuild in the projects section when I start. cheers Stephen
