I have a situation where if i turn the ignition on, my 20amp fuse blows instantly unless i leave the kill switch in the OFF position, then its fine. If i take the R/H switchgear off the bars, i can start the bike---- no probs.
I recently done some work on coils and headlight, so i may have disturbed something.   My trouble is im hopeless withh electrics.  What next?
Tommy
bad earth?
The kill switch is earthing out on the bars - check the wiring - it'll be dodgy
  probably wires squashed between bars & switch casing
						- z1000puddin
- z1000puddin
i did avalook inside the swichgear and it was a bit grotty: cleaned up wot i could get at. wires and soldering looked good. I`ll have alook again tmrw.
Oh... I replaced the frayed neg earth lead from batt to engine with the 9inch Halfords item the other day: slightly thicker. Shouldn`t be a problem should it?
Thanks boys
Thanks boys
sweptail wrote:i did avalook inside the swichgear and it was a bit grotty: cleaned up wot i could get at. wires and soldering looked good. I`ll have alook again tmrw.
Thanks boys
The bigger the earth the better.
Jimmock.
I hate people I don't like !
