no spark
				keith mayall
no spark
got new coils new points and condenser,plenty of juice in the battery ,but no spark..if the alternater wires are compremised{blue plug}could this be the problem.not removed alternator cover yet,engine has been out of frame .
				keith mayall
- Mark Tiller
				keith mayall
keith mayall wrote:I don't have a multimeter,to check but I don't think so,also the earth wire which ataches to the little grill thing above battery on right sde gets warm.Mark Tiller wrote:do u have 12v at coils?
Do you mean above or below the battery? It sound like a combined regulator/rectifier. What bike is it on? Ultimately you are going to need a meter to trace the problem or better still someone that knows zed electric s if you are uncertain. There maybe someone on here who is local to you who can help.
				keith mayall
z900 a4 don't have that earth wire on the crank,all the electrics work epcept no spark..thats whats frustrating.z1bman wrote:the main earth from the battery bolts to the top crank case just above the kick start & there is a short piece of earth wire coming from the negative battery terminal & plugs into the main wiring harness
				keith mayall
just above the battery opposite from the coloured plugs.its a a4..powder coated frame.all the lights and indicators ect work.ZedHead wrote:keith mayall wrote:I don't have a multimeter,to check but I don't think so,also the earth wire which ataches to the little grill thing above battery on right sde gets warm.Mark Tiller wrote:do u have 12v at coils?
				keith mayall
				keith mayall
