VM 28 or VM 29s
				Lee McEvoy
 - Regular Poster
VM 28 or VM 29s
Is there a way of telling the difference (without measuring the insides) between the 28s and 29s?
- Mark Tiller
						- z1000puddin
- big green bus
				snotie1965
Re: VM 28 or VM 29s
I do not think he meant "smooth bores"Lee McEvoy wrote:Is there a way of telling the difference (without measuring the insides) between the 28s and 29s?
Re: VM 28 or VM 29s
snotie1965 wrote:I do not think he meant "smooth bores"Lee McEvoy wrote:Is there a way of telling the difference (without measuring the insides) between the 28s and 29s?
The 29mm only came as smoothbores.
				snotie1965
Re: VM 28 or VM 29s
I always thought that GS1000 S used 29 mm ? but it would not be the 1st or last time ive been wrongzed1015 wrote:snotie1965 wrote:I do not think he meant "smooth bores"Lee McEvoy wrote:Is there a way of telling the difference (without measuring the insides) between the 28s and 29s?
				Lee McEvoy
 - Regular Poster
Re: VM 28 or VM 29s
snotie1965 wrote:I always thought that GS1000 S used 29 mm ? but it would not be the 1st or last time ive been wrongzed1015 wrote:snotie1965 wrote:I do not think he meant "smooth bores"Lee McEvoy wrote:Is there a way of telling the difference (without measuring the insides) between the 28s and 29s?
Gs1000 used either 26mm or 28mm slides depending on model before going to CV's.
The 998cc homologation Katana used 32mm smoothbores (the 1100 used CV's)
smootbores
i recently got some gs1000 parts and was told 1 set of carbs where off a katana 998cc does the inside of the carb body change into an oval shape rather than staying round all the way through??
mark
						mark
Re: smootbores
markz9 wrote:i recently got some gs1000 parts and was told 1 set of carbs where off a katana 998cc does the inside of the carb body change into an oval shape rather than staying round all the way through??
mark
Yes! They are oval at the venturi.
   PROPER SMOOTHIES
