Wiring harness
Wiring harness
Been looking at making up a Z1 wiring harness and I have managed to source all the materials to make one up except for the four coloured conectors in the centre part .
The replica harnesses available use them so they must be available from somewhere right?
I have read elsewhere on the forum that they have had trouble finding these so any pointers would be appreciated.
If successful I would be willing to make them up for club members to save a few quid!
Cheers Guyz.
Cheers Guyz.
if you mean these i think they where made specifically to fit the bracket that holds them together
http://www.z1parts.net/product/kawasaki ... ng-harness
you could e mail this company see if they can get them fore you. they do all the jap terminals & connector blocks
http://stores.ebay.co.uk/AutoStar-Shop/ ... 513&_pgn=2
Cheers Scot thats a start
 I have only been able to find connectors with flat pins not round pins like these coloured connectors.
All the other multi connectors in the Z harnesses have 2.8mm flat blades and are readily available. Can you remember where you found the white centre type connectors.
Cheers Dave.
Cheers Dave.
Yes mate EMGO wont sell to Joe Public just authourised dealers.
The only compromise is to use the original coloured connectors from the original harness and clean them up using new connection pins of course (which is the important part)
Problem is they do tend to get a little heat damaged due to bad / high resistance connections particularly on the alternator connector.
So frustrating not being able to make up complete new harnesses for the sake of four connectors.
Cheers Dave
Cheers Dave
Frustrating is not the word.....it's an absolute piece of piss to make harnesess.....if you can get that specific type of connector....it has to be the exact one......there is a genuine market for these connectors but they will not sell to anyone....how do you become a distributer for Emgo is the question
You will only end up with the same issues if you use the old connectors...has to be new
- steve bowdler
This company supply EMGO parts maybe worth chatting to them
http://www.motorcycle-superstore.co.uk/ ... motorcycle
these do a vast range of connectors so worth a phone call or e mail
http://kojaycat.co.uk/epages/950000457. ... s/MT8-CONN
