Idle
Wayne1960
Idle
#1 PostAuthor: Wayne1960 » Mon Jul 14, 2014 8:33 am
Can anyone explain how to adjust the throttle and carbs so that the bike will idle at the specified revs.
At the moment when I let go of the throttle the motor cuts out.
The screw on the carb body doesn't touch the throttle wheel on the carbs yet so I'm guessing the cables need adjusting to pul on the wheel to keep the revs up.
Bike now finished what a joy!
weaver
#2 PostAuthor: weaver » Mon Jul 14, 2014 10:38 am
the screw should be adjusted to lift the wheel off its stop to give an idle,if the throttle cables were used there would be no slack in the cables and it would give a poor action and the revs would probably rise when the handlebars are turned side to side
#3 PostAuthor: zed1015 » Mon Jul 14, 2014 12:16 pm
Slacken off all throttle cables.
Screw in the idle screw until it touches the throttle wheel.
Start the bike and adjust the screw so the engine idles at around 1000 revs.
Carefully adjust out the slack on the opening pull cable and then the same on the closing cable.
Leave a tiny amount of slack so the cables aren't pulling against each other.
Snap the throttle a couple of time to settle everything then re-adjust the idle to 1000rpm when warmed up.
Wayne1960
#4 PostAuthor: Wayne1960 » Mon Jul 14, 2014 5:47 pm
I'm wandering if I have the wrong spring on the idle screw. When it is screwed in tight the screw end doesn't reach the throttle wheel to start with. The spring measures about 10mm when fully compressed!
weaver
#5 PostAuthor: weaver » Mon Jul 14, 2014 6:09 pm
is the throttle closing fully? if not it wont reach the screw,the throttle cables could be too short,routed wrongly or maladjusted
steve bowdler
#6 PostAuthor: steve bowdler » Mon Jul 14, 2014 6:18 pm
Are all your cables slack as was mentioned earlier :( any pics ?
cheeme
#7 PostAuthor: cheeme » Mon Jul 14, 2014 6:28 pm
Wayne - Its worth checking the inside of the throttle bodies to make sure the butterflies are closing fully. I had a similar sounding issue with mine - adjuster not making contact, although mine was suffering from high revs. There was a slight buildup of 'black stuff' on inside which was enough to stop the butterflies closing and therefore the lever never got to its full resting point. I cleaned them out with some wire wool and a through good blast of air to make sure there were no nasty bits of wire left behind.
Shaun.
'80 Z1000H, '04 BMW R1150RT
http://cheeme.weebly.com (My Restoration Project Blog Site)
Wayne1960
#8 PostAuthor: Wayne1960 » Mon Jul 14, 2014 6:37 pm
Ok I'll have a look. The throttle and cables fell really good and when I let the throttle go it returns and stops positively. The cables have not been adjusted really they are on there up tight settings. The throttle wheel rotates and stops positively. Without the spring it reaches fine.
#9 PostAuthor: Pigford » Mon Jul 14, 2014 6:37 pm
[quote="cheeme"]Wayne - Its worth checking the inside of the throttle bodies to make sure the butterflies are closing fully.[/quote
They're proper "slide" carbs on a Z900 - not CV :wink:
Wayne1960
#10 PostAuthor: Wayne1960 » Mon Jul 14, 2014 6:39 pm
Ok throttle bodies?????? You mean the throttle on the handlebars?
#11 PostAuthor: z1bman » Mon Jul 14, 2014 6:49 pm
its a z900 a4 & has carbs.as i have already mentioned the problem is the slide height adjustment. the slides are sitting too low in the carb body
weaver
#12 PostAuthor: weaver » Mon Jul 14, 2014 7:37 pm
think someone needs to pop round and eyeball the bike to iron out the problems
Wayne1960
#13 PostAuthor: Wayne1960 » Mon Jul 14, 2014 8:57 pm
It's ok I'll get there. Got new points coming tomorrow so change them over.
I understand what you mean by slides and I didn't adjust them because they were exactly how they said in the manual, I think!
The last bike I had was when I was 17, I'm now 54 and a little rusty. I have however just built it from scratch, with a little help from my friends on here!
Just checked the cables and they feel ok and took the throttle apart and it looks ok.
Wayne1960
#14 PostAuthor: Wayne1960 » Tue Jul 15, 2014 11:42 am
I think I have the cables connected wrong on the throttle wheel at the carbs. Does anyone have a good picture showing the cables connected to the wheel with the locking nuts?
#15 PostAuthor: zed1015 » Tue Jul 15, 2014 12:15 pm
Those lock nuts do not go together.
One of the nuts need to be on the underside of the bracket and the other above so that they sandwich the bracket.
The bottom one is prevented from turning by a small protrusion on the bracket.
