First Start
I will sort out he wireing and voltage to the oils as you have suggested. I also removed the air filter and put my hand over the air in takes one at a time and it sucked on my hand which then got covered in petrol.
I guess that's what it should do if I cover the inlet entirely!
Bike now finished what a joy!
Ok done the spark test and it did jump 6mm and nice and blue. Had the spark plug gap wrong and adjusted. Also checked the spark at the plug and looked good. Put tank on and turned it on, same old same old nuffin!!!!
I'm loosing the will to live now.
So ignition on
Kill switch on
Petrol on
Choke on
Throttle open
Press start
Everything spins and thumps but no life!
So frustrating
Checked timing and checked cam chain at TDC on 1&4
So ignition on
Kill switch on
Petrol on
Choke on
Throttle open
Press start
So frustrating
Throttle shut! not open*******************
Which coil and cylinders are the left hand set of points feeding?
Have you tried a drop of fuel in the cylinders as previous posts?
How have you set ignition timing?
Fresh fuel and plugs
If you have compression,spark and fuel/air at the correct time bike should run.
Keep at it it will be something simple!!!
Hi Paul
Ok will keep throttle closed
The left hand coil feeds cylinders 1 & 4
No to fuel in cylinders so could try that
I believe I have the ignition set up ok and checked
Fuel was fresh I guess I could change it
Plugs are new
Plugs are new
