rotor off crank
- PETER KZ1A
rotor off crank
hello gentlemen
Strugglin to remove the above
Read the manual
Crankshaft is tapered,holding woodruff key,rotor stubborn as f@@k.
There is a serious knock at idle when bike is running,think this is wear of rotor to key.
Prick to remove rotor from crank.Reluctant to resort to prybars/hammers
Any clues?
Read the manual
Any clues?
paulmceleney
- Chunks
you can use front wheel spindle bolt, or the top yoke bolt both fit .I use a chain and rachet used to remove oil filters from cars, with a rag wrapped around the rotor to protect it, hold tight with the rachet tighten bolt in when comes to a stop keep tightening and it will come off you might need to get someone to hold the rachet for you to stop the rotor turning and you tighten the bolt
paulmceleney wrote:you can use front wheel spindle bolt, or the top yoke bolt both fit .I use a chain and rachet used to remove oil filters from cars, with a rag wrapped around the rotor to protect it, hold tight with the rachet tighten bolt in when comes to a stop keep tightening and it will come off you might need to get someone to hold the rachet for you to stop the rotor turning and you tighten the bolt
+ 1 - I use the top yoke bolt, but I used a nylon strap to hold the rotor still
Re: rotor off crank
PETER KZ1A wrote:hello gentlemen
Read the manual
Any clues?
If the rotor is stuck to the crank so tight, how could a worn rotor or crank slot/woodruf key be causing a knock ?
It could be that the starter clutch unit has come loose from the rotor. That happened on my first Z1, however the rotor still has to be removed to have a look.....
If it ain`t broke.....don`t fix it
C90
W650
ZRX1200R
Z1A
C90
W650
ZRX1200R
Z1A
Re: rotor off crank
Compo1955 wrote:PETER KZ1A wrote:hello gentlemen
Read the manual
Any clues?
I would be looking the magnet carrier the softer alloy carrier will be loose on the tapered and hardened core . Its a pre cursor to the whole feckin lot exploding !
Keith
mistaken.
Phil Churchett winner 2013
mistaken.
- PETER KZ1A
PETER KZ1A wrote:Got the rotor off the crankshaft this morning,complete with starter clutch,thanks for the info.
However,there is radial play between these two items.....
Is this normal?
Should be no play. Have the bolts come loose ?, or is the radial play between the steel rotor center and the main ally rotor body as was mentioned in an earlier post by Keith Z1R.
C90
W650
ZRX1200R
Z1A
C90
W650
ZRX1200R
Z1A
- PETER KZ1A
- PETER KZ1A
- Blackhat 999
- Regular Poster
+1 just replace the lot chain and rubber rollers tensioner guide and the little shock absorber rubber blocks it will sound like a different engine
Keith
mistaken.
mistaken.
wilsonsjw11
Users browsing this forum: Google [Bot] and 24 guests
