Part I'd
Thanks for this. Not sure if it applies to my A4 I can see the indicator relay and I have one of those.
I am still having probs with my hazard switch!
The book says to pull up the hazard switch when ignition is on or in park and the indicators will work.
Mine only work if ignition on and indicator switch turned to the left or right!!
Everything seems ok with all other lights and controls.
Any ideas?
Any ideas?
Bike now finished what a joy!
Ok thanks for all your help here. i want to get this right and install if i can whats missing.
I have indicators x 4
1 indicator flasher relay
Hazard switch
Am i missing the following and how do i identify them?
Buzzer
Hazard relay 27002-016
Hazard regulator 21066-024
do they fit as the pic above and where does the sounder fit?
Hazard switch
Buzzer
- steve bowdler
the buzzer fits on to the bottom of the headlight shell with an 8mm bolt
buzzer part no 27040- 002 csm have only got one left in stock $40.50
original hazard relay no longer available but this is identical & much cheaper you will just have to find the rubber that it fits into & is used to mount it on the battery box
http://www.ebay.co.uk/itm/CLASSIC-ROUND ... 4897.l5658
hazard regulator
indicator buzzer
hazard regulator
indicator buzzer
I skipped the buzzer on my A4 and fitted a modern type,the standard one sounds like a srtangled cat on helium bit emabarrasing when you turn up at bike meets
Looking forward to seeing your bike Wayne after all your hard work,sure it will be worth it.....
