The bolts I am referring to are the two M12 lower engine mounts that uses the Steel "segments " instead of normal nuts.
The threads on one of them are in very poor condition , I want to change them but I have no idea what the thread details are apart from metric fine.
Can anyone help?
Z900 A4/A5 engine mounting bolts thread and pitch
Gavin
I make it M12 x 1.25 pitch - that's taken from my Z1B and using thread gauges and is 70mm long so take it there is a difference between model numbers.
Zpower only list 1 size replacement bolt for the A4 at M12 x 55 long
https://www.z-power.co.uk/merchantmanag ... cts_id=834
Hope that's of some use.
Wots up DOHC
Just in case its the 'pear shape' nuts as well have a browse on there listings
https://www.z-power.co.uk/merchantmanag ... _20&page=7
Wots up DOHC
jimmock wrote:After reading this thread again.
I'm almost certain that the two bolts in question are DIFFERENT lengths.
and you would be correct
Keith
mistaken.
Phil Churchett winner 2013
mistaken.
